09-10-2019, 05:16 PM | #1 |
Rep 5,032
Anyone tried the Turner FTAB monoball?
Had the RE monoball ftab on my e9x m3, but saw that Turner has one for the f8x, so wanted to see if anyone has any experience with it. Thanks.
09-20-2019, 09:38 PM | #2 |
///M Powered for Life
11480
Rep 10,328
I have the Bimmerworld version but i don't think there are big differences between the different types
Bottom line is the mod has no negatives and plenty of positives |
09-20-2019, 10:24 PM | #3 |
Rep 715
I have them. Tightens the feel through the wheel.
M4 Times (PSC2): Sandown: 1.21.76 Winton: 1M Times (PSC2): Phillip Island: 1.53.09 Sandown: 1.24.03 Calder Park: 1.07.31 Winton: 1.36.71 |
Spun Crankhub963.50 |
10-07-2019, 06:56 PM | #4 |
Rep 303
As an alternative to a monoball, I’ve been looking at Rogue Engineerings polyurethane based bushing. I’m thinking it would reduce some of the harshness of a monoball, but still be a giant step up from the Oe bush.
Anyone tried the Rogue poly FTAB ? Last edited by M2C AW; 10-08-2019 at 01:53 PM.. |
10-08-2019, 06:37 AM | #5 |
Rep 1,239
Greatly involves steering feel but makes a little humming cabin noise. If a little noise bothers you, then I suggest you shouldn't get it. I also have the Fallline Motorsports Rear Upper Control Arm Steel Bearing.
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
10-09-2019, 05:40 PM | #6 | |
11480
Rep 10,328
Nothing really strange to do. No coolant lines. You will want to unscrew the bottom bolts holding the front side intercoolers/radiators so that you can remove/install the long bolt that holds them The only not so easy part is removing the old rubber bushing and inserting the new one |
10-09-2019, 09:59 PM | #7 |
Grid.Life
325
Rep 383
10-09-2019, 11:01 PM | #8 |
Rep 5,032
I’ve got the BMW bushing press tool, and also a bench top press from Harbor Freight, so I should be covered to remove OE install my RE mono.
Ive been in behind the wheel liner, and the only difference between F8X and E9X will be the coolers needing to be loosened to access the thrust arm bolts. |
10-10-2019, 06:50 AM | #9 |
11480
Rep 10,328
exactly! So if you have the right tools or just take them to a shop it's really really easy
10-10-2019, 06:50 AM | #10 | |
11480
Rep 10,328
03-22-2020, 12:19 AM | #13 |
Rep 1,976
How does it improve steering feel? More impressions please. Does it get rid of some of the numbness?
03-24-2020, 12:06 AM | #14 |
Rep 859
Plenty of time to look into these and found this on the M3 forums, gonna try the track/blue version, softer than monoball:
Rogue-Engineering-Front-Tension-Arm-Bushing The monoball kit is really meant for a track/race car only, it would be way too much for a street car in terms of NVH. Although some people are okay with it. If you drive on the street at all, I recommend the street version of this upgraded bushings. The track version is still softer than the mono ball. Harold (from HP Autosport) Last edited by fanatic1; 03-24-2020 at 01:58 PM.. Reason: Clarification |
05-24-2020, 01:15 AM | #15 | |
Rep 5,032
