      07-11-2019, 01:35 PM   #1
stevehifi
Drives: 17 F80 M3 ZCP
M2C competition brakes on F80m3/F82m4
HI Guys,
Has anyone replaced the stock brakes with the M2C calipers and larger rotors on a F80 M3/M4?
Is it a direct bolt on to the stock steering knuckle?
Do you need the different brake booster as well? (the one used with cars with the CCB option)?
Thanks,
Steve
      07-11-2019, 03:40 PM   #2
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
Originally Posted by stevehifi View Post
HI Guys,
Thanks,
Steve
It's discussed in another thread. Conclusion: It's plug-n-play, and you don't need to replace the brake booster since a different brake booster is used to compensate the different coefficient of friction on CCB.
Instagram:catpupu_f80
      07-11-2019, 11:41 PM   #3
stevehifi
Thanks I priced out the parts and it's over $5k with the pads... also limits your wheel options to 19"+.
///Mani36.00
      07-12-2019, 01:24 AM   #4
DanMpower
DanMpower's Avatar
Drives: BMW M3s and a Red VW
Interesting, I thought the different CCB brake booster was necessary because of the larger calipers and not because of the friction differences between iron and carbon ceramics.
      07-12-2019, 01:28 AM   #5
aBMWfan
Drives: 08' M3/'15 M4/ '06 M3/ '09 M3/
Then in that case. You would been a new booster for a BBK. You don’t. It’s for the ceramic friction
      07-18-2019, 05:25 PM   #6
farbmw
farbmw's Avatar
Trinidad_and_tobago
422
Drives: 2015 M4 6SPD MANUAL!
I am wondering if you could share the part numbers for this and the price you worked out, it's getting close for me to do a brake job and I would want to upgrade to the M2 comp brake system.
Thanks in advance!
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526
      07-18-2019, 06:51 PM   #7
theMpower
Spain
12
Drives: G82 xDrive + G20 M340d
Just installed in my M4 F82.
I have installed new CCB brake calipers (yellow), M2C brake discs, Endless ME22 brake pads, metal hoses and racing brake fluid.
I have also coded the calibration of the M2C brake booster with 2NH. Great improvement.
      07-18-2019, 07:18 PM   #8
stevehifi
What calibration do you need to do? I thought it's a simple plug and play and that you don't need to change the booster.
not sure what N2H means, can you elaborate?
      07-18-2019, 07:22 PM   #9
stevehifi
Thanks in advance!
just go to realoem.com for the part numbers and then go to bmwpartspros to look up the part numbers and pricing... it comes out to just over $5k
I don't see very many pad options for the calipers though aside from OEM
      07-19-2019, 07:28 AM   #10
OzcarM3
Drives: F80
if you use 380mm rotors, they will work with 19" wheels and just squeeze in some 18's.
Here's mine with FL-5's.[IMG]undefined[/IMG]
      07-21-2019, 10:30 PM   #11
stevehifi
has anyone coded m2c brake booster calibration? is it really needed or can you just run the brake kit as is?
How is pedal feel?
Nitrile19.00
      07-21-2019, 11:45 PM   #12
aBMWfan
How is pedal feel?
You can run the kit without a different brake booster. I’m 100% on this.
I run a Brembo GT kit and assume the pedal feel is similar to this kit. It’s more linear and predictable. The more you put down the more it will bite, and so forth
      07-22-2019, 04:29 AM   #13
jamiesecker
jamiesecker's Avatar
Drives: M4 CP
Guys, sorry to ask but I cannot get the M2 Comp 400mm OEM part numbers for the discs front & rear?
just purchased a set of CCD calipers to upgrade onto my M4 Comp.
any help greatly appreciated,
Regards,
Jamie
BMW E36 M3 Track car, Safety Devices role cage, Recaro Pole position seats, Bilstien Suspension, BBK, Poly bushed.(in factory white).
BMW F10 M5 Dailey driver.
      07-22-2019, 06:44 AM   #14
behindthen0thing
behindthen0thing's Avatar
840
Sorry to butt in here, but are you saying the M2C has better brakes than a regular M4?
I thought they were the same.
      07-22-2019, 06:53 AM   #15
jamiesecker
Drives: M4 CP
The M2 upgrade brakes are 400mm and slightly larger than the 380 fitted to my M4 Comp.
regards,
Jamie
      07-22-2019, 09:47 AM   #16
stevehifi
Front:
34118745793 caliper left
34118745794 caliper right
34118058655 dust shield left
34118058656 dust shield right
34118072017 brake disc left
34118072018 brake disc right
34116862801 (2) expansion spring
34116850934 (2) guide pin
34111123072 (4) hex bolt holding rotor to hub
34356792289 wear sensor
34116780509 (2) ventilation cap
34116780508 (2) dust cap
Rear:
34218745797 caliper left
34218745798 caliper right
34118072019 brake disc left
34118072020 brake disc right
34216857151 (2) expansion spring
34218046255 (2) guide pin
34211161806 (4) hex bolt holding rotor to hub
34352284656 wear sensor
34116780509 ventilation cap
34116780508 dust cap
Appreciate 6
JsL447.50
TopJimmy5458.50
david51537.50
      07-26-2019, 01:27 AM   #17
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2020 BMW M2 Comp  [0.00]
2020 BMW X3M Comp  [0.00]
2011 BMW 1M  [0.00]
HI Guys,
Thanks,
Steve
Yep, direct bolt on.
Appreciate 6
      07-30-2019, 05:59 PM   #18
stevehifi
for the gold calipers which anti rattle spring and guide bolts do you use?
is it these part numbers:
34116862801 (rattle clip/spring)
34116850934 (guide pin)
This is of course using pads for iron rotors
      07-30-2019, 06:44 PM   #19
phoenx
Drives: E46 M3, F80 M3, Tacoma, GT4 RS
Interesting. Got any more pics of this setup? Any other modifications you had to make? I currently have carbon ceramics but have thought about doing something like this because Im frustrated with lack of wheel options. Not a fan of 20's.
      07-31-2019, 10:52 AM   #20
MPOOR
MPOOR's Avatar
Drives: F80 M3 / WHITE
very true ~ you really need to crank up that piston force on CCB kit.
What shall i buy for my next track toy
      07-31-2019, 10:58 AM   #21
yayaya
Drives: BMW 335xi E92 N55
What is the benefit of doing this over F8x brakes?
      08-01-2019, 08:43 AM   #22
OzcarM3
Drives: F80
only other photo I have is with my standard 20" wheels.
did a track day last weekend with my 18" without a problem.
note however, I use 380mm rotors.
phoenx332.50
sly1types431.50
