Go Back   BMW M3 and BMW M4 Forum > Classifieds > Sponsors Classifieds > Suspension / Brakes / Chassis / Spacers
      01-22-2015, 12:32 PM   #1
AutoTalent
AutoTalent's Avatar
2309
Drives: e92 M3 6mt | e60 M5 6mt
AutoTalent | KW Suspension Oldest Dealer | KWV3 | ClubSport | H.A.S. |
AutoTalent | KW Suspension | BMW F80 F82 M3 M4 |
Applications: V3 | ClubSport | H.A.S.
Please PM or email: Golan@AutoTalent.com for pricing and info!
We are the oldest KW Suspension dealer!
KW V3: Adjustable Rebound & Compression Damping
Part # 352200AN (No EDC) / Part # 352200AP (With EDC Delete Module)
Want full control? The KW V3 gives you multiple settings for both rebound and compression. You have full access over ride comfort and handling to dial in that perfect setup. Race teams rely on adjustments to get that perfect lap time and having shock controls at your fingertips is key. KW V3 features -
Separate adjustments for compression (14 positions) and rebound (infinite settings),
Stiffer springs over stock for less bodyroll than the standard suspension,
Stainless steel strut/shock bodies and composite spring perches for superior corrossion resistance,
  • Individually height-adjustable:
  • Front = 25-45mm lowering
  • Rear = 25-50mm lowering
TUV approved lowering range and operation,
Expert engineering and design for ease-of-use and long durability,
Whether you track the car often or only use it for backroad carving the V3 will give you the tools to set up an ideal handling condition. You can crank it up for smooth and fast surfaces or soften it for city or rough roads. Since each shock is 2-way adjustable you can alter the front-rear balance to account for brake dive or squat during power application coming out of the corner. You are in total control!
Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires.
KW 2-Way Clubsport:]Adjustable Rebound & Compression Damping, Front Camber Plates & Stiffer Springs
Part # 352208AN (3-Bolt Application) / Part # 352208BB (5-Bolt Application)
KW Clubsport coilovers was developed for F80 M3 & F82 M4 owners who demand a better handling car when participating in track day events, but also require a setup that could be used every day. The Clubsport was specifically designed for the Nordschleife using track day tires. By using the adjustable camber mounts, the suspension geometry can be adjusted to the requirements of tires and the intended use. The mentioned adjustment options combined with the independently adjustable rebound and compression damping technology allow a suspension setup according to the vehicle load, tire characteristics and different track conditions. KW Clubsport meets every demand regarding a coilover for the usage on the road and the race track.
KW Clubsport suspension kits are independently adjustable in compression and rebound and include high performance racing springs. Racing front camber plates are included for further performance. KW Clubsport guarantees excellent handling, best performance, highest agility and fantastic lap times.
Performance setup for the racetrack
Height adjustable coilovers:
  • Front - 15-40mm
  • Rear - 20-45mm
Dampers in compression & rebound forces independently adjustable
Use of high performance linear race springs: Front 575 lbs/inch, Rear 800 lbs/inch.
Stainless steel technology "inox-line"
Includes front camber plate mounts [/B]
How to Place Your Order:
Phone Domestic: 310-231-0292
Phone International: 310-231-0292
E-mail:
Website:
www.AutoTalent.com
Payment:
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
      02-02-2015, 03:21 PM   #2
AutoTalent
AutoTalent's Avatar
2309
Bump!
      02-02-2015, 09:40 PM   #3
Black Gold
Clubsport price to 77002 no edc kit needed. F80 m3. Thanks
      02-03-2015, 02:56 PM   #4
AutoTalent
AutoTalent's Avatar
2309
e92 335i in today for some KWV3 Coil Overs + OEM M3 Control Arms!
      02-06-2015, 01:17 PM   #5
AutoTalent
AutoTalent's Avatar
2309
Bump!
      02-09-2015, 01:00 PM   #6
AutoTalent
AutoTalent's Avatar
2309
Bump!
      02-12-2015, 02:45 PM   #7
AutoTalent
AutoTalent's Avatar
2309
Bump!
      02-17-2015, 06:04 PM   #8
AutoTalent
AutoTalent's Avatar
2309
Bump!
      02-23-2015, 03:31 PM   #9
AutoTalent
AutoTalent's Avatar
2309
Bump!
      03-03-2015, 03:21 PM   #10
AutoTalent
AutoTalent's Avatar
2309
Bump!
      03-09-2015, 04:34 PM   #11
AutoTalent
AutoTalent's Avatar
2309
Bump!
      03-19-2015, 05:28 PM   #12
AutoTalent
AutoTalent's Avatar
2309
Bump! I guarantee the lowest price on any KW system or they're free
      04-07-2015, 04:44 PM   #13
AutoTalent
AutoTalent's Avatar
2309
Bump!
      04-09-2015, 02:02 PM   #14
AutoTalent
AutoTalent's Avatar
2309
Bump!
      04-14-2015, 03:17 PM   #15
AutoTalent
AutoTalent's Avatar
2309
Bump! We have H.A.S. , V3 and ClubSports all IN STOCK and ready to ship same day. PM for pricing!
      04-14-2015, 06:13 PM   #16
mshab356
Go ///M or go home
mshab356's Avatar
Drives: 2015 F80 M3 6MT
Hi can you please send me pricing on KW HAS for F80 M3 no adaptive EDC shipped to 22182. Thanks.
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT
      04-21-2015, 01:32 PM   #17
AutoTalent
AutoTalent's Avatar
2309
Bump!
      04-24-2015, 01:46 PM   #18
AutoTalent
AutoTalent's Avatar
2309
In Stock!
      05-27-2015, 03:48 PM   #19
AutoTalent
AutoTalent's Avatar
2309
We have H.A.S., V3s and Clubsport applications IN STOCK available to ship same day!
      06-08-2015, 02:11 PM   #20
AutoTalent
AutoTalent's Avatar
2309
Bump! Can ship these same day!
      06-14-2015, 10:42 AM   #21
mkhan526
mkhan526's Avatar
Drives: 2015 M3
Can you send me prices for all 3 setups. Thanks
2015 Bmw M3
Jb4, er downpipes, kW clubsports
Follow me on Instagram @mkhan_m3
      06-30-2015, 01:31 PM   #22
AutoTalent
AutoTalent's Avatar
2309
bump!
