      09-21-2021, 02:52 PM   #1
heitzke
heitzke's Avatar
1153
Drives: '15 M4 base, '04 Cobra
TE37SL center cap adapters just... don't fit
I'm not sure why i'm surprised by this after really thinking about it and looking at them rationally, but there's literally no room on these wheels for the center cap adapters to work correctly.
The f/r hubs just extend into the space where the adapters would sit, so what are my options here?
Basically the only valid option I can think of is to run some small spacers and give them room to sit. I don't know that I have enough room in the rear though, and honestly at this point i'm tired of spending money to have center caps lol.
Other than that, I guess I can always just try to sell all this stuff and then wire brush/paint the hub centers black. I'd much rather have center caps tbh, but I just don't see how they can work.
Wheels are 19x9.5 +21, 19x10.5 +35.
Mosselman-powered M4 - 698/714 | 2.9 Whipple 2004 Cobra - 690/645 | Instagram
      09-21-2021, 05:36 PM   #2
knightarmor
Drives: 2017 M3
Just get something designed and 3D printed to fit properly.
heitzke1152.50
      09-21-2021, 06:03 PM   #3
dms-01
dms-01's Avatar
1133
Drives: 2018 F80 M3
When I had my SLs I plasti dipped those centers black and then cleared them. Looked better than the rusted hubs sticking out. I don't think I've ever seen an F80 with SLs and center caps that fit but YMMV.
heitzke1152.50
      09-21-2021, 09:20 PM   #4
blaccm3
blaccm3's Avatar
Drives: 18' BSM F80 M3
2018 BMW M3  [0.00]
Sell them and buy ultras lol jk.. best option is prob what knightarmor said
heitzke1152.50
      09-22-2021, 10:32 AM   #5
heitzke
heitzke's Avatar
1153
Yeah that's probably what I need to do here. Doesn't seem like it's impossible to do.
Definitely on my to-do list now once I finish all the flex-fueling stuff now. Rusty hubs aren't a great look poking out through these wheels
Haha I wish! I guess i'm just a little caught off guard by the situation and assumed everything would be alright when it should be been obvious that it wasn't going to fit lol.
      09-27-2021, 07:18 PM   #6
humk721
Drives: 2016 BSM F80 M3
I used to work for a company that sold Volks and had connections with Mackin Industries (main distributor for Volks / Rays in North America). Mackin Industries informed me that SLs aren't compatible with centercaps. There's ways people made them work but they weren't easy
      09-28-2021, 08:48 AM   #7
heitzke
heitzke's Avatar
1153
Yeah that's why they require adapter rings to fit standard caps. Unfortunately the F8X hubs just aren't compatible with this sort of setup.
      09-28-2021, 11:10 AM   #8
TD-F80
TD-F80's Avatar
110
Drives: 2017 SO M3
I had the same issue with my SL's. I eneded up using a rubber ring aroung the cap to hold it in place. haven't lost a center cap yet. fingers crossed
heitzke1152.50
      09-28-2021, 11:18 AM   #9
heitzke
heitzke's Avatar
1153
Haha that works for me - how'd you manage the rears though!? There's like.. basically no room back there
      09-28-2021, 11:25 AM   #10
TD-F80
TD-F80's Avatar
110
Drives: 2017 SO M3
I had just enough space for the cap and ring.
heitzke1152.50
      09-28-2021, 02:01 PM   #11
heitzke
heitzke's Avatar
1153
Ok cool thanks, where/what sort of rubber ring did you end up using for this? This solution sounds perfectly fine in my book
      09-28-2021, 02:44 PM   #12
TD-F80
TD-F80's Avatar
110
Drives: 2017 SO M3
I bought some rubber clamps used for plumbing at home depot that matched the right size and cut them to the correct thickness, here is a pic from the back.
heitzke1152.50
Ramzzz1.50
      09-28-2021, 02:49 PM   #13
heitzke
heitzke's Avatar
1153
Nice! Thanks and appreciate the help
TD-F80110.00
      11-05-2021, 12:49 PM   #14
ac419
ac419's Avatar
Taiwan
19
Drives: 2015 BMW M3
2015 BMW M3  [0.00]
Sorry a newb to TEs, so SL's requires some work to make the center caps fit. While Ultra M spec fits center caps. Is that true? Thanks
      11-07-2021, 01:49 AM   #15
blaccm3
blaccm3's Avatar
2018 BMW M3  [0.00]
Saga/Ultra will fit center caps with no adapters.
      11-08-2021, 11:25 AM   #16
ac419
ac419's Avatar
Taiwan
19
Drives: 2015 BMW M3
2015 BMW M3  [0.00]
Thanks for the info.
Has anyone tried these adapters? https://www.evasivemotorsports.com/s...m-30mm-o-ring/
      11-08-2021, 11:28 AM   #17
heitzke
heitzke's Avatar
1153
Yep unfortunately. That's what I posting this thread about. The way the SL's fit and the design of the F8X hubs - the adapters don't have space to fit at all.
      11-08-2021, 11:34 AM   #18
ac419
ac419's Avatar
Taiwan
19
Drives: 2015 BMW M3
2015 BMW M3  [0.00]
That's a total bummer. I see where the hub comes out too much for the adapter to fit. Would dremeling out the areas where the hub sticks out work?
      11-08-2021, 11:38 AM   #19
heitzke
heitzke's Avatar
1153
Potentially could, but I wouldn't want to modify the hubs at all. I ended up going with the solution that @TD-F80 came up with. I fit the fronts easily, but need to spend a little more time getting the rears to really sit well.
Wheels look a lot better and more finished with the caps imo.
TD-F80110.00
      05-03-2022, 10:58 PM   #20
manat.0
Don't know if anyone found a response to this but I fit center caps on my SLs on my f82. Had a shop with a lathe shave the back of the adapters to make them fit. If you're in the DC area; RRT will do it.
heitzke1152.50
      05-04-2022, 07:42 AM   #21
heitzke
heitzke's Avatar
1153
That's helpful to know. I ended up throwing some small spacers on the front wheels anyway, so my fronts work but my rears are still using the "rubber gasket" method. Many thousands of miles they're still holding strong, but I really should just get them machined down.
      06-02-2022, 12:31 PM   #22
ChrisRoman
Drives: 2022 M340i
any info on what rubber pieces you used to make it work
