09-08-2017, 10:36 AM | #1 |
Rep 1,203
Drives: 2021 M2C
Winter tires - square setup on 20" 666M wheels
I know it's still summer but I'm already planning my winter wheel setup. I will be getting aftermarket wheels next year so the 20" 666M wheels will be used for winter duty. I'm thinking of wrapping these in a snow tire square configuration of 275/30/20 all around. I know they'll fit the rear 10" wide wheel fine, but will 275 fit ok on the front 9" wide wheel? Will it bulge too much or in any way be unsafe? I like the idea of a square tire set up. As the rears wear, they can be swap mounted with the fronts instead of buying a new pair of rubber.
09-08-2017, 11:35 PM | #2 |
Rep 385
If you don't drive in much snow the 275 is okay but probably a bit too wide if you live in an area with lots of snow.
BMW recommends square tires on their own winter wheel/tire packages. I ran a 275 summer tire on 9.5 on the front of my previous F80 so you can do it but it's not ideal. Something in a 255 section width would be better for winter driving overall and closer to what BMW recommends. I plan on running a 255 Bridgestone Blizzak LM32 on my 666's 255/35/20 |
09-11-2017, 03:20 PM | #3 | |
Rep 3,803
09-11-2017, 05:13 PM | #4 |
Rep 1,203
Drives: 2021 M2C
09-11-2017, 05:16 PM | #5 |
Rep 3,803
08-09-2018, 12:54 PM | #6 | |
Rep 354
08-22-2018, 07:21 AM | #7 |
Rep 64
Resurrecting this thread as I'm also in the market for winters. I thought about getting some for the 666s, but now I'm leaning towards 19s.
Tomorrow is Not Promised.
Increase the Peace. Be the Change You Want to See in the World. |
08-22-2018, 07:49 AM | #8 |
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
unless you have CCBs, id highly recommend selling the 666Ms or even the 437Ms and grabbing a set of 18s for winter duty. my car came with 513Ms and i immediately put on 255 winter tires (square). the looks aren't glamorous but they do the job and finding winter tires at these sizes are much easier.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
09-04-2018, 06:13 PM | #9 |
Rep 1,203
Drives: 2021 M2C
I ended up going with 245/35/20 front and 275/30/20 rear Michelin PA4. I tried 275 in the front and it was a no go, was rubbing the inside strut as the sidewall on these tires are very thick. The shop where I had installed was nice enough to rush order the 255 tire the same day and it fit's nicely. No problems at all riding with this setup all winter and it looks great.
09-05-2018, 10:04 AM | #10 | |
Rep 2,192
M3 CP in THE fastest colour (says so in the title )
09-05-2018, 10:08 AM | #11 | |
Rep 354
I called bmw and they told me not to put winter tires on the 20 inch wheels as it could cause damage. I assume that's their canned response since they haven't formally validated any tires for the 20inch wheels. They are pushing their 19 inch wheel/tire package of course. |
09-05-2018, 12:46 PM | #12 |
Rep 354
I posted this on a separate thread. Thought I'd post my findings here as well:
Michelin has available today the Alpin PA4: 285/30/20 XL 99W (# 10712) There's a new tire on the way: Aplin PA4: 265/30/20 XL 94W (# 04620) According to Michelin customer support, the new 265 (04620) will be available by the middle or end of this month. I will wait patiently for now. I'll post any updates if i hear anything. |
09-23-2018, 10:53 PM | #14 | |
Rep 264
09-26-2018, 02:25 PM | #15 | ||
Rep 264
09-26-2018, 04:28 PM | #16 | |||
Rep 354
09-27-2018, 09:53 PM | #17 | ||||
Rep 264
10-17-2018, 02:39 PM | #18 |
Rep 64
Anyone here putting winters on their 20" competition wheels? I'm thinking of the Alpins in 245 fronts and 275 rears based on what I have read here.
10-17-2018, 02:57 PM | #19 |
Rep 1,009
The biggest fear in using 20" tires during the winter isn't necessarily traction considering you're using winter tires. It's the 30 profile tires. If you hit a pothole or slide into a curb, chances are your tires will get cut and you'll end up stranded. You'll then realized that your wheel is also damaged and it will be very costly to get a replacement winter wheel/tire setup during the middle of winter when selection is pretty limited.
Jlpvt0.00 |
10-17-2018, 03:14 PM | #20 | |
Rep 64
10-17-2018, 05:22 PM | #21 | |
Rep 354
Coming in November is a 265/30/20 (front) in a 94W that matches the rear. However, others on this forum have been told that the 265 will not be here until January. I'm waiting until about 3 weeks into November before I abandon ship and find some 19's. |
