09-22-2020, 08:43 AM | #1 |
Rep 190,807
ARM Motorsports S55 M3 M4 Downpipes, Charge Pipes & Exhaust Tips *** NEW PRODUCTS ***
ARM Motorsports F87 M2C M3 M4 DOWNPIPES
HIGHLIGHTS • Up to +30whp / 30wtq • Enhanced Exhaust Note • 304 Stainless Steel • Improved Turbo Spool PROFILE The ARM F87 M2 Competition Downpipes are the ultimate solution for improving power, throttle response, and exhaust note on your S55 powered F87 M2 Competition. Our goal for the ARM F87 M2 Competition Downpipes was to provide a solution that would maximize power and torque, fit perfectly, and sound extraordinary. Catless downpipes are considered a standard upgrade for any F87 M2 Competition owner looking to safely push their S55 engine beyond basic Stage 1 tuning. With Stage 2 and up tuning, higher boost increases back-pressure at the OEM catalysts and chokes the S55's turbochargers, causing them to work harder and shortening their life. F80 M3 Downpipes S55 Resonated ARM The ARM F87 M2 Competition Downpipes relieve the stressful back-pressure caused by high-boost tunes, allowing the exhaust to flow freely, increasing power and torque, all while extending the longevity of your S55's turbochargers. On our test car, after installing our F87 downpipes and switching to a Stage 2 flash we made 539whp/544wtq, this is 68whp and a massive 127wtq gain over just the Stage 1 flash! F80 M3 Downpipes Dyno Stage 2 Even with the Resonated ARM F87 M2 Competition Downpipes installed on your stock-tune S55, you will notice an increase in power, torque and responsiveness. Not to mention the incredible, head-turning sounds your M2 Competition will make under part and full throttle. RUMBLE, NOT RASP. The ARM Resonated S55 Downpipes give your F87 M2 Competition an unparalleled sound that even other F87 owners will notice. The deep, aggressive tone of the ARM F87 M2 Competition Resonated Downpipes will stand out next to the all too familiar high-pitched rasp of other catless downpipes. Our x" resonators are installed in the perfect location to enhance the sound of your S55 without compromising the precise fitment of our F87 M2 Competition downpipes. CONSTRUCTION Precision CNC machined v-band flanges offer a smooth transition of exhaust gasses from the the turbochargers to the ARM S55 Downpipes. The body of the 3" ARM F87 M2 Competition Downpipes are constructed of SS304 Stainless-Steel and are threaded smoothly and perfectly though the space given by BMW towards the mid-pipe section. F80 M3 Downpipes S55 Resonated ARM Any downpipes that bolt up directly to the OEM mid-pipes must reduce to the 2.5" to meet the size of the OEM mid-pipes. Some aftermarket downpipes use an abrupt, short reducer which causes turbulence in the exhaust gasses. The ARM F87 M2 Competition Downpipes feature a smooth, gradual transition from the 3" inlet to the 2.5" exit for optimum exhaust flow. F80 M3 Downpipes S55 Resonated ARM The ARM F87 M2 Competition Downpipes are a massive improvement over the OEM S55 downpipes, with precise fitment and brilliant finish the ARM S55 Resonated Downpipes are the perfect solution for your S55 project. Our goal for the ARM F87 M2 Competition Downpipes was to provide a solution that would maximize power/torque, fit perfectly, and sound uniquely extraordinary. We are so confident that you'll agree we've achieved this, we back every set of our ARM F87 M2 Competition Resonated Downpipes with a 30 Day Money-Back Guarantee and the ARM Lifetime Free-Replacement Warranty. IN THE BOX • ARM F87 M2 Competition Resonated Downpipes • CNC Machined Bracket for Front-Turbo Downpipe • 4x Downpipe to Mid-Pipe Bolts/Nuts • ARM Lifetime Replacement Warranty FITMENT GUIDE Make Model Submodel Engine BMW F80 M3 S55 3.0L BMW F82 M4 S55 3.0L BMW F83 M4 S55 3.0L BMW F87 M2 Competition S55 3.0L ARM Motorsports F87 M2C M3 M4 CHARGE PIPES HIGHLIGHTS • Maximize Power by Replacing Boost-Leaking OEM Charge Pipes • Full T6061 Aluminum Construction • Built for High-Boost Applications • Discrete Dual Meth/Nitrous Port Locations • Precision CNC Machined Turbo Connections PROFILE The ARM F87 M2 Competition Charge Pipes allow you to maximize power on your M2 by securing all the boost that your S55 is making. The stock S55 charge pipes are notorious for developing hairline fractures at their plastic seams. These fractures or cracks are unnoticeable to the naked eye, but under boost pressure they open up leaking the desired charged air into the engine bay, and consequently can rob your S55 of it's full power potential. In addition, these leaks can trigger your S55's turbochargers to work harder to hit and maintain target boost pressure, potentially wearing them out sooner. The ARM F87 M2 Competition Charge Pipes replace the OEM plastic S55 charge pipes, ensuring that all of your charged air makes the transition from the turbos to the intercooler. CONSTRUCTION The ARM F87 M2 Competition Charge Pipes are made entirely of T6061 aluminum, allowing them to handle the highest boost pressures and therefore, the ability to grow with your build. We rely on our ARM S55 Charge Pipes to channel the boost on our project F80 with upgraded turbos, making over 700whp. So whether you are just Stage 1 or making 900hp, the ARM S55 Charge Pipes will work for your project. The ARM F87 M2 Competition Charge Pipes utilize precision CNC machined flanges for mating up to the turbochargers' compressor outlets seamlessly, creating a secure, leak-free seal. The ARM S55 Charge Pipes are coated in a black wrinkle finish for a classy yet durable look. Each charge pipe is equipped with a methanol/nitrous port located towards the back of the charge pipe. The meth/nitrous hookups are positioned to allow for running the supply lines discreetly, making them unnoticeable from a glace under the hood. IN THE BOX • ARM S55 Charge Pipes • Silicon Couplers • Meth Caps • Clamps FITMENT GUIDE Make Model Submodel Engine BMW F80 M3 S55 3.0L BMW F82 M4 S55 3.0L BMW F83 M4 S55 3.0L BMW F87 M2 Competition S55 3.0L ARM Motorsports F87 M2C M3 M4 EXHAUST TIPS HIGHLIGHTS • Fits OEM and Aftermarket Diffusers • 304 Stainless Steel • Direct Bolt-On • ARM Lifetime Warranty PROFILE The ARM F87 M2 Competition Exhaust Tips give your M2 a stunning modified look that installs in minutes and is backed by the ARM Limited Lifetime Warranty. The large 90mm ARM M2 Exhaust Tips dwarf the small tame look of the stock M2 tips to give your F87 a more complete and aggressive look. ARM F87 M2 Competition Exhaust Tips are a direct replacement for the stock M2 exhaust and do not require any trimming or welding. They are secured using a single hex bolt which minimizes any unsightly extra clamps or hardware to keep a clean and stunning look. The ARM F87 Exhaust tips fit the stock rear diffuser and almost all aftermarket diffusers. CONSTRUCTION Created from 304 Stainless Steel, the ARM F87 M2 Exhaust Tips are comprised of a 2.8mm double wall construction for durability that lasts. IN THE BOX • 4x 304 Stainless Steel Tips FITMENT GUIDE Make Model Submodel Engine BMW F80 M3 S55 3.0L BMW F82 M4 S55 3.0L BMW F83 M4 S55 3.0L BMW F22 M2 Competition S55 3.0L More Pictures:
09-23-2020, 09:53 AM | #2 |
Rep 571
It keeps referring to F87 but I assume it works with F82. Got any sound clips? Also do you know if it fits with an AA midpipe?
"If you have everything under control, you're not moving fast enough"
09-23-2020, 03:37 PM | #4 | |
Rep 190,807
These downpipes fit the M2C, M3 & M4
09-28-2020, 12:41 PM | #6 |
Rep 190,807
We guarantee fitment, if you dont like it you can send it back. We do not charge any restocking fee
10-06-2020, 09:43 AM | #7 |
Rep 190,807
New version with a flex section
10-07-2020, 07:11 AM | #8 |
Rep 3,788
Can you PM me the forum price on the new version with the flex, resonated DPs, please?
Do the production units have the ARM Logo on them? |
10-07-2020, 09:29 AM | #9 |
Rep 190,807
Its got the name on them as shown in the pictures
10-28-2020, 12:20 PM | #10 |
Rep 190,807
12-10-2020, 09:49 AM | #11 |
Rep 190,807
12-24-2020, 02:48 PM | #12 |
Rep 190,807
01-11-2021, 06:00 PM | #13 |
Rep 190,807
01-26-2021, 05:59 PM | #14 |
Rep 190,807
02-11-2021, 03:38 PM | #15 |
Rep 190,807
02-27-2021, 02:17 PM | #16 |
Rep 190,807
03-17-2021, 12:29 PM | #17 |
Rep 190,807
04-01-2021, 05:50 PM | #18 |
Rep 190,807
04-16-2021, 05:58 PM | #19 |
Rep 190,807
05-18-2021, 05:47 PM | #21 |
Rep 190,807
06-03-2021, 11:59 AM | #22 |
Rep 190,807
