Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      06-26-2018, 08:57 PM   #1
CigarPundit
On the road to serfdom
CigarPundit's Avatar
Drives: 2018 F80 M3 DCT, 2019 Raptor
2018 F80 M3 DCT  [0.00]
Clicking Sound From Wheel When Turning
Anybody experienced this of have any idea what could be causing it?
"God bless our troops...Especially our snipers.”
      06-27-2018, 05:32 AM   #2
FlyingLow78
The G8X is a disaster. 🤮
931
Drives: Not a BMW anymore
Sounds like you have a screw or nail in the tread of a front tire. On the left front tire check the inner shoulder. On the right front tire check the outer shoulder.
      06-27-2018, 08:22 AM   #3
CigarPundit
That was my first thought, but the tires are okay.
Bl0ck101.00
      07-03-2018, 10:53 PM   #4
joludo
Drives: 20 M4 CS
I have the same issue. Took it to the dealer they said rocks in the brake rotor backing plate. Picked it up still doing it.
      07-04-2018, 08:28 AM   #5
M4BUM
M4BUM's Avatar
32
i have the same problem
get the clicking only when i turn right
found out, that this is a known problem with the f series
especially the f10/11/12/13 has the same clicking noise
there is a PUMA case with the number 62105224
https://shop.bmw.de/bmw-de/de_DE/Tei...e95/page1.html
i will buy the discs and try the next days
rvacha62.00
      07-04-2018, 11:07 AM   #6
cbae1010
I had the same problem...more pronounced when turning right.
Got it fixed at the dealership.
Here's the parts that they used
(4) 31-10-8-053-073 Disc for higher coefficient
(2) 83-19-2-180-806 Brake cleaner
(4) 34-11-1-123-072 Inner Hex Bolt.
I didn't really get a good explanation from the dealer, but told me it's the sound from Rotors and calipers as they expand and contract due to temp changes (??). Anyways, the added discs appear to be shims and I'm guessing it's just taking some play out of the rotor.
So far, I don't hear the noise anymore and it appears to have done the tricks.
rvacha62.00
      07-04-2018, 11:35 AM   #7
Canuckles
Canuckles's Avatar
Drives: MW 2016 F82 M4
I had the above fix initially which never fixed my problem. Ended up having to replace my wheel bearings under warranty and its been 8 months since I've heard the clicking while turning.
      07-04-2018, 03:10 PM   #8
M4BUM
M4BUM's Avatar
32
than you should check your carriers on both sides, maybe they have too much clearance
part number for the left side: 31212284001
      07-04-2018, 03:58 PM   #9
CigarPundit
Thanks guys, much appreciated. It's going to the dealer on Friday.
      07-16-2018, 12:47 PM   #10
FirstF80InSpace
///M You
FirstF80InSpace's Avatar
Drives: 2019 Porsche 718 Cayman S
Any update on this? I will be bringing my car in next week to address the ticking sound which only happens when turning right.
      07-16-2018, 12:51 PM   #11
CigarPundit
The dealer installed the paper spacers (see post # 5). Seems to have fixed it.
      05-02-2019, 09:47 AM   #12
neverhadm3
Drives: 2017 SO/SO M3
That is the exact same sound I'm having but it's coming from the rear wheel and it's constant whether I'm turning or not. Anybody got that fixed? already took it to the dealer and they claimed they fixed it and it came back the next day
      05-02-2019, 01:29 PM   #13
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
Check your tire tread for anything stuck in there.
      11-22-2022, 09:56 PM   #14
victorboost
Drives: 2016 BMW M3
Any definite solution for this? Mine started both ticking in the front at the same time when i installed and then removed the spacers. I’ve ruled out the brake dust shields, not sure what to attack now 😅
      11-30-2022, 06:13 AM   #15
EricP3
EricP3's Avatar
693
Drives: '23 X3M Comp
https://f80.bimmerpost.com/forums/sh....php?t=1618945
2016 M3 6MT, Yas Marina Blue/Silverstone - Sold
2023 X3M Competition, Brooklyn Grey
