Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      11-26-2022, 09:29 PM   #1
Fourleaf tayback
Fourleaf tayback's Avatar
Drives: 2016 F82 M4 YMB
2016 BMW M4  [0.00]
Oil in Front Charge Pipe and TMIC
Hi all,
I was changing my spark plugs and air filters on my 2016 M4 (60,000 miles) and when I pulled off the charge pipes I noticed a little oil in the front charge pipe. When I looked in the TMIC I noticed oil in the front intake where the front charge pipe attaches. I've read elsewhere on the forum that this is "normal" but as I'm currently buying new charge pipes (and potentially a new TMIC) I'm curious if this is the sign of an issue.
Attached is a photo of the TMIC:
      11-27-2022, 01:20 AM   #2
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
It is normal, the front turbo sucks oil vapors, and they condense in the intake
      11-27-2022, 04:34 AM   #3
s55jesus
M Enthusiast
s55jesus's Avatar
438
Drives: 2018 F80 M3 ZCP
  [0.00]
Had the same exact issue. Get a catch can.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC
2017 F30 340i (SOLD)
2015 F82 M4 (SOLD)
      11-27-2022, 08:08 AM   #4
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
Normal. Wipe it out with alcohol, and then ignore it. No probs.
Or get an OCC, which also requires cleaning out.
If you were on E85 the OCC would be recommended, but for gas not needed.
      11-29-2022, 03:45 PM   #5
andrei.m4
Drives: bmw f82
Turbo 1 leaking at all f80/f82. Catch can no difference. Inside catch can only water condensation. Ended up only with upgraded turbos and no more oil issue!
Also stem steals after 100k km burn some oil. I replaced all of this and in 5k km my oil level is still at maximum!
      11-30-2022, 04:38 PM   #6
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
You will not solve the condensation of oil vapors by upgraded turbos....
      12-01-2022, 03:55 PM   #7
SCS55
Drives: E90,F30, F80
My 2c……Normal……Did my plugs 2 weeks ago, took everything apart for cleaning (new O rings bottom of CP's) and same amount of residue as you.
2016
87,000 miles
No issues
      12-03-2022, 07:52 AM   #8
andrei.m4
Drives: bmw f82
I mean the oil he found here is not present because he not have catch can! The oil is here because turbo1 leaking on intake side.
In the past I replaced the turbo1 with a new one and after 4k km I was in the same situation!! The only way to clean here was upgraded turbos.( I run littco l640 uk).
Also with downpipe if smoke is present after little idle the problem is not the turbo1, the problem is the stem seals I know what I am talking here.
      12-03-2022, 07:35 PM   #9
M2_MEDUSA
M2_MEDUSA's Avatar
Drives: 2021 M2 Comp. SpecialEdition
Mine is the same way
Instagram: M2_Medusa
      12-08-2022, 10:57 AM   #10
Tangent
Drives: G01, F82, E89, F25
While you might or might not have a problem with a turbo, you'll get this even with perfectly sealed ones. The front pipe is where the vent from the valve cover connects so that's where the oil vapors are going to be deposited.
