ARMA SPEED
      12-10-2020, 01:10 PM   #1
teeess
Drives: F80 M3 (2015), F10 520d (2016)
How much power should my F80 M3 really make?
Hey guys,
I recently acquired a 2015 BMW F80 M3 which has the following mods:
  • Akrapovic Titanium Exhaust with catless downpipes
  • Eventuri Carbon Fibre intakes
  • Pure Stage 2 (non-plus) turbos
  • CSF Charge Coolers
  • CSF Intake coolers
  • BP Engineering Titanium charge pipes
  • NGK Racing Plugs
  • Mosselman Thermostat
  • Mosselman Crank Hub fix
Was planning on doing a conservative 95 ron tune or a 98 RON map at the most due to the bad fuel conditions here!
Can someone tell me what (Power/torque) figures can I realistically expect on these 95/98 RON maps respectively?
      12-10-2020, 03:24 PM   #2
tomlong
tomlong's Avatar
Drives: F80 M3 Sedan
Hard to say because many other factors are critical as well. Things such as the health of the motor, existence of boost leaks, and most important the tune (whether OTS or custom) that will be utilized all play a huge factor.
Upgraded turbos on low boost (22-25 psi) using quality 93 octane pump gas should see at least 600 whp would be my rule of thumb.
      12-10-2020, 03:32 PM   #3
teeess
I picked up the car with only 4,300 kms on the odo.The car has been primarily driven in rush hour traffic and only been tracked once.So I'm assuming the health of the motor shouldn't be an issue.What I was super curious about was would the Akrapovic downpipes hold the car from making its maximum power? As they are ~ 2.75 inches wide compared to 3+ inches on a VRSF/Evolution Race downpipe.Therefore causing a (0.25*2=0.5)inch difference as a whole
      12-10-2020, 03:40 PM   #4
tomlong
tomlong's Avatar
I think you'll be fine but if you're gonna upgrade @performanceeurowerks sells 3.5" downpipes for the S55 motor.
Tell them tomlong sent you. 😎
teeess1.00
      12-10-2020, 08:08 PM   #5
ALCOBENDAS
Drives: M3 F82
Friend whit this turbos ots map for big turbos 658hp at crank 98 ron
teeess1.00
      12-10-2020, 09:56 PM   #6
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
Attached is my dyno chart showing comparison of 3 datasets, all with stock motor, stock turbos, and stock fueling.
- Stock Tune (red and green lines) 421HP / 389TQ
- BM3 GTS Tune (orange and purple lines) 440HP / 435TQ
- BM3 Stage2 93 octane, 10% TQ reduced for a hub fix (blue and gray lines) 475HP / 450TQ
My car was in for a hub fix and I forgot that I had TQ reduction dialed into my Stage2 tune when we did the dyno pulls (DOH!). I estimate the real Stage2 output at 495HP and 485TQ. Testing was done at Kies Motorsports on their Dynapack (bolt-on wheel pods, real WHP).
Mods on Dyno day: MST Intakes, VTT CPs, Wagner TMIC, ER J-pipe, Stock Plugs, ER Hi-Flow Cats, AA Full 3.5 Exhaust, 93octane Pump Gas, no adders, no meth.
Adding Pure/VTT Turbos would increase by an estimated 75-100HP, and with HF+/GC+ by an estimated 100-130HP. This is with 93AKI premium pump gas.
teeess1.00
      12-11-2020, 10:54 AM   #7
Commanderwiggin
Commanderwiggin's Avatar
2050
Drives: M2C - X3M - Turbo E46 M3 - 45E
How much will it make?
The answer is simple...It's never enough
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
      12-11-2020, 01:36 PM   #8
nbennettksu
Drives: DV F80
We see consistent 498whp/520wtq in humid ass south FL in July and August. I'd say you're stronger than you think.
Originally Posted by JBasham View Post
Caddy ATS . . . finally, a decent rental car option.
Originally Posted by kchu221 View Post
the wheels make me mad...
Originally Posted by mhabs View Post
It's one thing for some buffoon to put an M badge on something that doesn't deserve it...it's another for a multi-billion dollar corporation to do the exact same thing and keep a straight face.
TopJimmy5458.50
      12-11-2020, 03:24 PM   #9
landonvan
landonvan's Avatar
72
Drives: 2015 f80 M3
2009 E92 M3  [10.00]
I have the GC’s. F80paul tune. DP, AA single mid, charge pipes, top mount on 93 pump. Made 621/639
TopJimmy5458.50
      12-11-2020, 07:21 PM   #10
TopJimmy
TopJimmy's Avatar
teeess there you have it... ALCOBENDAS had the precise number for the + turbos you have. landonvan backed it up 20HP less with non+ turbos. tomlong estimate was right.
nbennettksu thanks for the good input. I'll take 500/520 for bragging. Need to get back to Kies and re-run those Dyno pulls with my stock airboxes, and to fine tune Paul's E80 kill map.
tomlong617.00
      12-11-2020, 07:35 PM   #11
ALCOBENDAS
Drives: M3 F82
Sorry my english.. my friend not have + turbos, have HF turbos only full decat and bmc drop in filters.
Have 5,9 draggy times 100 - 200 kmh
2m311.00
      12-11-2020, 07:41 PM   #12
TopJimmy
TopJimmy's Avatar
Still good to help Original Poster know what numbers to expect. The Plus add a little more to high RPM pulls. If shifting 6200 or under the gain of + is only a little over non+.
      12-12-2020, 09:23 PM   #13
Carguy1994
ooooooooo
Carguy1994's Avatar
Drives: BMW M3 2018
Originally Posted by teeess View Post
Hey guys,
  • NGK Racing Plugs
Around 620 whp now, get port injection and methanol injection.
- 2018 F80 M3
- 2019 FORD RAPTOR
akrapovič, csf, eventuri, f80, mosselman, pure stage 2, s55, s55 engine tune, s55 m3, s55 performance
