01-24-2016, 11:07 PM | #1 |
Rep 838
New JB4 user. Help with Map 2 F82 M4 slight stutter E85/91.
Ive somewhat read about this online and also noted in N54tech. I guess some people have these problems too and maybe its too much E85, but id appreciate the help if anyone can.
Car and mods are F82 M4 DCT, BMS intake, VRSF down pipes, 4 gallons E85 the rest 91oct, 52 degrees outside. Having a slight stutter doing pulls on map 2. Map 1 seems fine. Doesn't a stock s55 get 16-20psi? Im only seeing 15 wish map 1 and 16-17 map 2. Is this correct?
19 MBB M5C
16 Yas MarinaM4 (gone) 05 E46 M3 HPF/ProEfi Stage 2.25 (Gone ) |
01-25-2016, 11:29 AM | #7 |
Joint Chiefs of Staff
4927
Rep 116,037
Looks like you set your boost safety too low and you are just running the stock maps. Best to post logs on n54tech if you need professional tuning support.
Mike |
01-25-2016, 12:58 PM | #8 |
Rep 838
yea they got back to me there. I had the user adjustable setting all zeroed out. I changed them to the default settings like Terry advised.
19 MBB M5C
01-25-2016, 01:00 PM | #9 |
Rep 838
What are you guys using for the max boost settings for 1st-3rd gear. Would really like to gain some traction as the 295's didn't help any lol.
19 MBB M5C
01-25-2016, 01:03 PM | #10 |
4927
Rep 116,037
01-25-2016, 01:05 PM | #11 |
Rep 838
what do you use? what is stock boost levels?
19 MBB M5C
01-25-2016, 01:08 PM | #12 |
4927
Rep 116,037
01-25-2016, 01:11 PM | #13 |
Rep 838
don't you mean set it low then? If you set it high say 22 wont it try to go that high vs say 16.
19 MBB M5C
01-26-2016, 08:55 AM | #14 | |
4927
Rep 116,037
Mike Last edited by Mike@N54Tuning.com; 01-26-2016 at 05:14 PM.. |
01-26-2016, 11:18 AM | #15 | |
Rep 838
19 MBB M5C
01-26-2016, 05:20 PM | #16 |
Rep 838
actually since i changed the default settings the stutter went away. I will do more runs today to make sure.
19 MBB M5C
