ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > UK
      05-05-2019, 11:15 AM   #1
hawkerj96
Drives: BMW M4 Convertibe
Rough Idle, Noisy Injectors + Whooshing!!
Hello again lovely people,
My M4 has developed a rough idle, noisy injectors and under acceleration it’s down on power and makes a whooshing sound that sounds like a boost leak??!
I haven’t got any warnings or lights at all.
I’m thinking it could be a blowing charge pipe or maybe the charge cooler is cracked??
Any advice?
Thanks
      05-06-2019, 04:02 PM   #2
hawkerj96
BUMP
r0wr589.00
      05-06-2019, 05:01 PM   #3
MrSmartyPants
Drives: F80 M3 - 6MT_MW on SO
Get under the hood and inspect parts for potential boost leaks/cracks. Seems like you've got an idea of what's wrong.
      05-07-2019, 02:01 AM   #4
hawkerj96
I do but I’ve got no CEL and have had no warnings at all but there’s a massive decrease in power, horrible whoosh noise under boost and the injectors seem to be very noisy!
      05-07-2019, 02:40 AM   #5
SteveChester
SteveChester's Avatar
Drives: F82 M4
2014 BMW F82 M4  [0.00]
Loose/split pipe - have you tried reading any codes from the OBD etc.
Steve Roberts UK
F82 M4
I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/
      05-07-2019, 04:44 AM   #6
t5pilot
t5pilot's Avatar
Drives: M4 CP & S1000 XR
Without looking or properly diagnosing, I'd say it's probably cracked charge pipe(s)....
/// BM3 + M-Power ///
      05-08-2019, 01:58 AM   #7
hawkerj96
Time to swap for an i8?
      05-08-2019, 08:08 AM   #8
Mmvic
Mmvic's Avatar
61
I had A large boost leak from charger pipes, same sound, no codes
      05-10-2019, 10:14 AM   #9
Paul SR
Drives: Touring
Have you had it checked at the garage yet?
      05-13-2019, 02:01 AM   #10
hawkerj96
I did initially and they said it was ‘normal’. Obviously isn’t. Guess just because it’s bit thrown any CEL. Defoe down in power and a boost leak there but I’ve checked the charge pipes and can’t pinpoint any obvious boost leaks
      07-20-2021, 02:23 AM   #11
chrisstrann
Stancenation Build
chrisstrann's Avatar
Drives: F06 M6
We're you ever able to find the issue? Same issue here.
