08-14-2018, 04:01 PM | #1 |
Rep 4,653
Finally going to fit this at the weekend - it needs drilling which is ok but I think I've read somewhere that those plastic flaps that just sit behind the bumper need trimming down?
It's a EBay copy not OEM
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
08-14-2018, 04:31 PM | #3 |
Rep 4,653
I'll post some once I've done it...
Steve Roberts UK
JustChris17487.50 |
08-15-2018, 02:03 AM | #4 |
Supreme Being
1804
Rep 5,425
I have the OEM (plastic) one and yes, the plastic deflector panel needs trimming on both the rubber and harder plastic material.
Took some time o get me head around it but the OEM kit comes with a template to help you cut. Could be tricky without.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
08-15-2018, 03:30 PM | #6 |
Rep 4,653
What does the template look like?
Steve Roberts UK
08-15-2018, 03:31 PM | #7 |
Rep 4,653
Steve Roberts UK
08-16-2018, 12:49 AM | #8 | |
Supreme Being
1804
Rep 5,425
https://f80.bimmerpost.com/forums/at...8;d=1416178907 First time around I couldn't figure out how to lay it out but it then made a sense after the first cut! I'm away at the moment but if you want a copy made/cut I can have a look when I'm back next week.
08-16-2018, 02:53 PM | #9 | ||
Rep 4,653
Sure between me and my old man we can sort it......
Steve Roberts UK
08-16-2018, 03:06 PM | #10 |
Rep 4,653
Also I've bought the splitter and the two L shaped covers for the front intakes - which one goes on first?
Steve Roberts UK
08-17-2018, 12:07 AM | #11 | |
Supreme Being
1804
Rep 5,425
If so, fit the lip upper carrier piece first (if the carbon lip has one of these? If it - ignore this step!) since it goes inside the bottom of the bumper and you do lots of pulling around of stuff. Then fit the carbon corners. Then fit the lip - you need to drill through the carbon corners to fit the plastic rivets so it helps keep them all true. I seems to recall the bits you need to cut go back on last anyway so you can get the whole job done them spend the time playing around and fine tuning your cuts. A Dremel type tool worked best for me.
08-17-2018, 06:50 AM | #13 |
Supreme Being
1804
Rep 5,425
Haha - I love this!
Wills28656.00 |
08-17-2018, 01:19 PM | #14 | ||
Rep 4,653
I'll be starting 8am tomorrow and it will probably take me all day
Steve Roberts UK
JustChris17487.50 |
08-18-2018, 08:36 AM | #15 | |
Rep 4,653
Think I've sussed it out....
Steve Roberts UK
08-18-2018, 08:46 AM | #16 | |
Supreme Being
1804
Rep 5,425
You not finished yet?
08-18-2018, 09:09 AM | #17 | |
Rep 4,653
Might need a copy of that template though... My splitter is one piece and need some longer screws as well.
Steve Roberts UK
08-18-2018, 09:23 AM | #18 |
Supreme Being
1804
Rep 5,425
Drop me a PM with your details and I'll make a template up for you.
08-18-2018, 09:25 AM | #19 | |
Rep 4,653
Steve Roberts UK
08-18-2018, 12:18 PM | #20 |
Rep 2,192
Have you a close up pic of the splitter fitted ?
M3 CP in THE fastest colour (says so in the title )
08-18-2018, 03:00 PM | #21 |
Supreme Being
1804
Rep 5,425
Here you go - some pictures along with an 'idiots guide' which SteveChester may find useful.
This shows where the deflector needs to be cut (red line) and shows the part retained (outlined in green). The template for cutting, marked up in red. Lay the template on the deflector, aligning the holes in the template with holes in the deflector. Front end picture showing the part of the soft rubber retained after cutting (green outline as before).
robwils759.00 |
08-18-2018, 03:28 PM | #22 | |
Rep 2,192
Rob
