01-04-2019, 11:52 PM | #1 |
Rep 754
F8X S55 owners BEWARE!! Charge cooler failure
Hello everyone,
I'm not around on this Section of the forum but have and still am gaining more knowledge of the S55, but am knowledgeable to the N54/N55 platform and linger on e90post/1addicts. Recently a buddy of mine with a F80 M3 has been receiving drivetrain malfunctions, down on power, and extremely hot air intake air temps, the charge air cooler as you guys know should be cool to the touch. Car goes into diagnostic at a local performance shop and find this: (see images below). After pulling the intake manifold off the car. Yes that's right, seems like the factory charge air cooler has leaked the cooling fluid through the core and gone directly into the intake manifold, and through the intake valves directly into the engine. From what I've seen this is the first that has happened on this platform. The car will be repaired and back running in a few days. But as a PSA seems like upgrading the stock heat exchanger to prevent a 2k+ failure/repair like this is the way to go.
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold 2006 Z4 M Roadster Black/Black-Sold 2021 M2 Competition DCT Hockenheim Silver Last edited by WeekendWarriorz; 01-05-2019 at 12:42 AM.. |
guess2098516.00 hatepotholez292.50 ra2289305.50 damageprone580.50 Lee808230.50 BMWjunkie89.50 RTCalifornia41.50 Machtavian60.50 bimm3rr1.50 kern4174446.50 Mii387.50 gman_newyork239.50 JTO245274.50 JackyStuntin154.50 bodega_bladerunner155.50 Xtabi1701.50 FrankMstein1018.00 |
01-05-2019, 12:36 AM | #4 |
Rep 754
Absolutely, I'm surprised it didn't hydrolock... but after the fluid drained into the engine it either went into the oil and can cause excessive wear on rotating parts (rod bearings for example) or evaporated with the heat generated from combustion. Whichever happened though it isn't good!
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold 2006 Z4 M Roadster Black/Black-Sold 2021 M2 Competition DCT Hockenheim Silver |
01-05-2019, 01:07 AM | #6 |
Rep 754
This was it if I recall correctly
FriedPiston1972.50 |
01-05-2019, 01:45 AM | #8 |
Rep 754
The car has only seen Newport Beach BMW and Mckenna BMW for routine service since new, both reputable dealerships in SoCal. Previously had a JB4 (junk box 4) on it over a year ago with a few hundred miles before being taken off is what I'm told. Nothing that could have been correlated to the failure In my opinion.
01-05-2019, 11:09 AM | #9 |
Rep 105
Drives: 16 M3, 02 M3
We have replaced two so far. Not caused by any mods. Both were internal core leaks.
WeekendWarriorz670.00 qmp123.50 hellokitty2895.50 MisterEm33.00 Relak247.00 bimm3rr1.50 kern4174446.50 JTO245274.50 |
01-05-2019, 11:30 AM | #11 |
Rep 105
one 15, one 16.
50k+ on first one, correct fluids and maintenance. Other was lower mileage. If you are losing fluid from the HX reservoir you know where its going if it isn't on the ground. |
01-05-2019, 12:11 PM | #12 |
Rep 754
This is a 2018, I believe around 15k miles.
01-05-2019, 12:23 PM | #13 |
Rep 1,095
Mine was leaking too and I had no codes. It's best to check the IC reservoir to if its leaking or not.
2016 M3 Alpine White / Sakhir Orange BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount) |
01-05-2019, 03:30 PM | #14 |
Rep 164
This doesn’t surprise me at all… However that is not the only place it can leak from as I found out about four months ago my charge coolant expansion tank had to be replaced because I had a slow leak although I saw no evidence or could smell anything either which was extremely odd. I just knew it was leaking internally. All is good now :-) sidenote, both my charge cooling expansion tank and engine block coolant expansion tank have been replaced one each. 2016 M4
01-05-2019, 04:19 PM | #15 | |
Rep 3,726
01-05-2019, 09:01 PM | #17 |
Rep 754
Better to be safe than sorry. Seems like there's been a few of these and no one has documented this failure. A used S55 + labor for a swap doesn't sound cheap as opposed to a CSF cooler in my opinion!
01-05-2019, 09:16 PM | #18 |
Rep 20,741
Water injection
01-05-2019, 11:52 PM | #19 | |
Rep 374
What shall i buy for my next track toy
01-06-2019, 08:48 AM | #20 |
Rep 6,863
For us laymen, is this something we could check and if so how?
G35POPPEDMYCHERRY4998.50 |
01-06-2019, 12:34 PM | #22 |
Rep 754
Open up the reservoir for the charge air cooler, I would just monitor it every few weeks. If you notice fluid dropping then there would be a concern. For example: you could use a straw and then the first time you measure use a sharpie and mark the height of the fluid.
khanyam4801.50 JacanF807.50 yasavguy39.50 papasmurf_m3454.50 8_is_enough197.00 JTO245274.50 Agent11br449.50 whoismorggan553.00 PhillyF806.00 matharu9039.50 phefner369.00 |
