      06-05-2021, 01:14 AM   #1
Rod_knee
Rod_knee's Avatar
26
Drives: 17 BMW M3 F80
Kw DDC with camber plates?
I just picked up a set of KW's DDC plug and play. As I was getting it prepped for install, I came to a realization that I should run camber plates since I will be taking the car to the track occasionally. Also these suspension uses the stock top hats. Is anyone running adjustable camber plates? Looking for some feedback if you are along with some thoughts. Also what are relatively good but yet affordable. Thanks in advance!
01' Nissan Skyline ER34
91' Toyota Cressida (drift car)
07' Toyota Tundra (work truck)
17' BMW M3 F80 (new addition)
Instagram: @Rod_knee
      06-06-2021, 10:21 AM   #2
Billy_BMW
Drives: BMW M2 Competition
The KW springs will use the OEM thrust bearing from your existing top mounts - it’s a black rubber swivelling piece.
Then buy these camber plates made in the UK:
https://suspensionsecrets.co.uk/prod...camber-plates/
They will work with your setup and allow up to 4 degrees. I’m running them with V3’s and they’re great.
      06-07-2021, 04:23 PM   #3
Rod_knee
Rod_knee's Avatar
26
The KW springs will use the OEM thrust bearing from your existing top mounts - it's a black rubber swivelling piece.
They will work with your setup and allow up to 4 degrees. I'm running them with V3's and they're great.
Thanks for the input!!
      06-07-2021, 04:53 PM   #4
clutchdj
Drives: a few cars
OP not sure what group you run, but if you have not installed them yet fyi they will ride quite soft on the track. I had them on 2 f8x cars
