02-21-2019, 12:57 PM | #1 |
Rep 282
Nut sheared in half, stuck on wheel stud
I was removing the nut from my driver's side front wheel (ironically to replace it and the wheel stud) when it sheared in half. Like the top half the socket goes over came off, and the cone-shaped bottom piece is locked in place, not allowing the wheel to come off.
Any suggestions for me? My local shop has tried a couple things they say, but nothing has worked. Their next step they would cut the stud off as close as possible and just dremel into it slowly. They estimate this to take a couple hours of labor though, and I'd rather not pay a couple hundred dollars. My idea was to weld a nut onto the end of the thread and just use that to remove the stud itself. They claim to have tried something similar and put enough force on it to where they thought the stud was starting to deform, so stopped. Ughhh. Last edited by TTGator; 02-22-2019 at 10:09 AM.. |
02-21-2019, 10:27 PM | #2 |
Rep 362
I had a stud shear inside the wheel hub that I needed to extract. I drilled into the stud a couple of times to make an opening where I could use a flathead screwdriver to spin the stud out. This will work assuming there is no torque on the stud as it was easy to spin freely with a flathead.
02-22-2019, 05:04 AM | #3 | |
Rep 282
Short video of it on my IG @ttgator |
Jockey3448.00 |
02-22-2019, 09:50 AM | #4 |
Rep 264
I've used kits like this in the past for my race car and it has worked well.
https://www.amazon.com/Extractor-Rem.../dp/B01M7XDBYF |
