09-16-2017, 01:21 PM | #1 |
Rep 56
Front strut clunking
Anyone have this issue too? 20k miles, 2016, non adjustable suspension. I noticed that it was a clunking kind of like when a strut goes bad. So I took it in and explained to them how it sounded and the foreman agreed to go on a ride with me, and he also heard the sound. But it’s odd to me that this would happen so early on a car like this. Just wondering if this is common. Confirmed the sound is 100% gone now, so I’m glad for that at least.
2018 M5
09-22-2017, 03:51 PM | #3 |
Rep 334
I have the same problem with aftermarket suspension. My coils were sent back to KW and they said nothing was wrong. I did the sway bar fix and still same noise. Since I changed the suspension, it's no longer covered under warranty. My next is to order part# 313 078 53702 which is the strut bearing.
Give an update when they figure out what your issue is. |
09-25-2017, 04:34 PM | #7 |
Rep 465
Interesting... I have JRZ coilovers and I have a slight clunking noise coming from the front driver strut as well. This is the only one that makes noise. My stock edc suspension was silent.
09-25-2017, 05:33 PM | #8 |
Rep 334
good to know it's not just me after installing KW V3s. I had no sounds with stock suspension and replaced with V3 when i had less than 1k miles on the car. I've been chasing the clunking sound for almost a year. I read the thread about properly tightening the sway bar and that didn't help. The shop that did my install even sent my front coils back to KW for evaluation and they found nothing wrong. the only thing left is #6 in the diagram as i mentioned.
the sound is only when i hit sharp bumps, street reflectors do it every time and speeds under 20mph |
09-26-2017, 10:44 AM | #9 |
Rep 334
09-27-2017, 11:41 AM | #10 |
Rep 56
Is that the same as the "upper mount" they replaced, per the techs notes?
Edit: yes it is. So in that case, it didn't fix it. You think the design is defective?
2018 M5
09-28-2017, 11:25 AM | #13 |
Rep 4,396
Drives: 2022 F97 X3M Comp LCI
UHHHHHH. na na na naaaa
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
09-28-2017, 01:28 PM | #14 |
Rep 56
I didn't check those myself but I they said they "checked the torque" of all the front suspension components. Dont know if that means sway bar too.
2018 M5
10-04-2017, 02:40 AM | #16 |
Rep 52
i've got the same noises / issues. It comes from the steering system (variable sport steering). Have a look for it in google and search for 3series / 4series steering issues. A replacement will only fix it for 10 - 15k miles, afterwards the noise returns...
They already swapped my strut, support bearing, my suspension, damper and so on.. Nearly the whole front of the chassis. Really a pity Currently i am in the second exchange period, although my car has only 15k miles on it. I am really thinking about returning the car, even tho it is the best car i've ever had. But whith these issues, a resell is impossible. The noises cannot be ignored.. |
10-05-2017, 07:27 PM | #17 |
Rep 334
wish there as a way we could accurately compare the sounds we're hearing.
i do know that i did not have the issue with stock suspension and noticed it shortly after the damper swap. |
10-19-2017, 09:13 AM | #18 |
Rep 56
I gave up for now, tbh. The sound is still there. I don't know the best way to compare our sounds. All I can do is tell you that it sounds exactly like a bad strut/shock or mount. I drove lots of beaters when I was a kid so it's a familiar sound.
2018 M5
10-19-2017, 04:26 PM | #19 |
Out in the middle of the sea
231
Rep 471
Having same issues only on drivers front side. Having it looked at this weekend
ericson11254.00 |
