      05-14-2018, 12:44 PM   #1
MikeeM3
Drives: 600whp M4
BMW M4 loud tickling engine sound... is this normal to you?
I own this car since late April and i noticed this loud engine sound ... is this sounds ''normal'' to you or i should be stressed about it
Car pulls strong and runs great ... 40k on the car !!
Thanks!!
      05-14-2018, 12:50 PM   #2
Agent - ///M
Agent - ///M's Avatar
Drives: 2018 F80 Comp; Black Sapphire
Tickling or ticking....
Why put off for tomorrow, what can be done today?
      05-14-2018, 12:51 PM   #3
Agent - ///M
Sorry I had to....
I'm all seriousness, it sounds almost like lifter noise if it's coming from the top of the motor.
Is that where it's coming from?
Last oil change done by BMW or independent?
      05-14-2018, 12:58 PM   #4
BzsBimmer
BzsBimmer's Avatar
3271
Drives: '23 G80 FO M3, M3 & MY Tezzy's
First one in to say.... rod bearings lol
      05-14-2018, 12:59 PM   #5
MikeeM3
Drives: 600whp M4
my first language is french so hey give me a chance here lol
      05-14-2018, 01:00 PM   #6
MikeeM3
Drives: 600whp M4
Sorry I had to....
Yes top of motor !! Last oil change done at BMW like all other previous oil change !!
      05-14-2018, 01:01 PM   #7
MikeeM3
Drives: 600whp M4
Its not an e9x lol
      05-14-2018, 01:38 PM   #8
FriedPiston
Drives: Scraper
Sounds normal based on what I believe is reasonable/acceptable engine noise, and there are two F80s in my garage: 2017 ZCP (fully modified with 11k miles) and 2018 ZCP (bone stock with 6.9k miles).
The noise is very common on the F8x, and it could vary from belt tensioner, injectors or valve lifters. Some have had actual issues with short valve lifters from the factory (http://f80.bimmerpost.com/forums/sho....php?t=1052412) that eventually got repaired under warranty, but it's quite difficult to tell the difference over a video. It's best to take your car to the dealer if you're concerned by the slightest bit, especially considering how you're near the end of warranty coverage.
Edit: As for the tickling sound, it could be due to kinkiness, and since you claim to be French, that may just explain things...
Also see:
      05-14-2018, 05:13 PM   #9
JamesGames
JamesGames's Avatar
Drives: E60 550i|F82 M4|F48 X1|VA STi
Direct injection tick..
      05-14-2018, 05:34 PM   #10
M3anPower
That's normal.
      03-18-2019, 02:27 PM   #11
CAOZKAN
Italy
98
Drives: Austin Yellow M4
Thanks!!
Mine started to make similar sound after rebuilding the engine with forged rods and pistons. It happens at certain rpm and tad a bit louder idle. I'm suspecting from valve lifters or the injectors. Do you have it at certain rpm as well? (Between 1500-2200) Did you find what it's really about?
      03-18-2019, 04:06 PM   #12
Champagne_Reign
Champagne_Reign's Avatar
Drives: 18 Champagne Quartz F80 M3 CP
got 11000+ on my 2018. Makes same noise, but not as loud as yours. Its the lifters most likely. BMW use's 0w30, a very thin oil (in my opinion). A thicker oil is recommended if you don't want the noise.
      03-18-2019, 07:57 PM   #13
maximumeffort
Drives: 2019 BMW x3 M40i
Possibly Lifters IMO.
Does it get better after a few miles/minutes?
      03-18-2019, 08:18 PM   #14
TKT2SPEED
TKT2SPEED's Avatar
140
Drives: 2022 G80M3 Comp X Drive
sounds like injectors to me
      03-24-2019, 09:02 PM   #15
Andrew30azs
Drives: BMW m4
Mine doing the same like on this second video on the up on this page. Dealer said this is just the louder lifters and i dont have nothing to worry about it. But to be honest im worry about it - sometimes the noise sound like mettalic tapping and in my opiinion it is not normal for a car what worth like 70k . When the car is fully warm up the noise goes away.
      04-02-2019, 02:05 PM   #16
justbaeM4
Drives: 2015 BMW M4
this is still going on my 15 M4 as well and the dealer wanted 2k to inspect it so i told him to go eff off....
      04-02-2019, 03:15 PM   #17
Andrew30azs
Drives: BMW m4
Dealer already inspected this problem on mine car and they said it this is just a lifters .
      04-03-2019, 05:49 PM   #18
MarinoB
MarinoB's Avatar
Croatia
282
Drives: '17 F80 M3
At around 20k mikes mine started sounding just like that. Car runs strong like always but at idle sounds like a truck.
      04-04-2019, 11:11 AM   #19
Andrew30azs
Drives: BMW m4
Call to Bmw USA America north , and explain them. Please take tawny to phone - I reported this issue there if a lot people explain this ticking maybe they will replace for us under warranty the lifters
      05-04-2019, 10:28 AM   #20
Andrew30azs
Drives: BMW m4
What do you think guys can i use the addative to oil ?
      05-05-2019, 07:34 AM   #21
Groganrocket
Drives: 2010 e90 335i and 2015m4
Originally Posted by M3anPower View Post
That's normal.
+1 that’s normal
      05-05-2019, 11:57 AM   #22
FmauriM4
Drives: 2015 BMW M4
Mine has a healthy tick as well. Likely the injectors or lifters. No tickling though😉
