11-09-2015, 11:19 PM | #1 | |
Rep 109
Active Sound gone after latest software update?
RESOLVED
Why did this happen? This happened when the dealer updated the the software for a few different ECUs in the car. I don't know exactly which ECUs they touched, but ASD was one of them, and subsequently, ASD stopped functioning. The update applied was to fix the problem of ConnectedDrive/RTTI not working, here is a well documented thread on this problem with 2016s: http://f80.bimmerpost.com/forums/sho....php?t=1169492 How do I get it to not happen to me? If you can live with the ConnectedDrive/RTTI not working, then don't ask the dealer to touch your software, and you will be fine. In retrospect, not having RTTI was way less of a problem than a borked ASD ECU. Oh no! This already happened to me. How do I fix it? - The Simple Way: Tell the dealer that the ASD ECU software is not functioning properly and requires a re-flash, and tell them to re-flash it. Your dealer may or may not be able to handle this without causing other issues. - The Straight Forward Way: Obtain coding cable and coding software, and re-flash the ASD ECU yourself. ONLY RE-FLASH THE ASD ECU. NOTHING ELSE. Here is a good thread on becoming familiar with the coding software and its processes: http://f80.bimmerpost.com/forums/sho....php?t=1125375, meanwhile, here is another thread that deals with the specific procedures in flashing an ECU entirely, rather than re-coding it: http://www.bimmerfest.com/forums/sho...d.php?t=694166, please read them thoroughly. Carelessness could end up wrecking your ECU. - The Correct Way:
You might run into quite a few different hiccups in the process above of not having the right file or not being able to generate the right file. That's normal. Feel free to ask questions.
Current: '16 F80 AW/SO 6MT, '16 BMW R Nine T
Past: '13 W204 C63 MCT, '12 MKII TT-RS 6MT, '11 E92 335is 6MT, '06 MKV GTI 6MT Last edited by Stryder; 11-15-2015 at 11:11 AM.. |
11-10-2015, 12:27 PM | #2 | |
Rep 516
Post 1200 mile breakin service car behavior http://f80.bimmerpost.com/forums/sho....php?t=1185119 I found someone else with the same problem as me, but they didnt mention the sound. I definitely notice a difference in mine. PM me if you want talk more about this. I have just been getting "nocebo effect" from everyone here. |
11-10-2015, 02:27 PM | #3 |
Rep 381
Drives: 2022 G82 Xdrive
yeah sound was lost too initially. that's how I first notice something felt strange after breakin..
afer few hundred miles and playing with sport/ sport+ , everything seems normal and no further issue. |
11-11-2015, 01:10 PM | #4 |
Rep 109
Well, just to confirm that I'm not totally out of my mind:
- Talked to dealer, they pulled the warranty sheet they submitted for the update, and confirmed that they updated the ASD module using ISPI NEXT. I don't think they chose to update ASD specifically, and just did it blanketed update for everything. - Coded the car this morning, changed ASD module 3000 model range to F020/F021, *no sound difference*, so yeah, ASD was definitely off. - Downgraded ASD module software *slightly*, since I was already on the latest software, but I downgraded from cafd_00000f9b-001_020_003 to cafd_00000f9b-001_020_002. Drove around a little, didn't notice too much of a difference, but there might have been a small one. - Found a "Competition Paket" option, turned that on, I think that produced a small amount of difference on my way to work. Probably just placebo. Don't have time to play with this more until later tonight, but there was a material difference from the software update in how ASD behaves. To many, this will be a welcomed change. To others like me, it's kind of annoying - I thought the sound engineers did a good job creating an aural experience. The car is loud on the outside, but pretty damn quiet on the inside without some "fake noises". It's also possible that the ASD module needs to "relearn" after software changes and gets louder over time, or it's simply just the user becoming accustomed to the new reality. Not a whole lot I can do at this point because I'm on the latest firmware and downgrade options are limited, if I can manage to find an older CAFD file for the ASD module that actually works with the latest firmware, then that might be something to try. All in all, I hope these findings are helpful.
Past: '13 W204 C63 MCT, '12 MKII TT-RS 6MT, '11 E92 335is 6MT, '06 MKV GTI 6MT |
11-11-2015, 01:22 PM | #5 |
Rep 6,248
^^ Good stuff Stryder.
Since you can't really "hear" the ASD (or at least I can't), I have a hard time deciding if I l like it or not. I guess the real option is to unplug it and see if I notice a difference. FWIW, my car has a 10/2015 build date, but it might get a new ISTA/P when it hits the VDC? |
11-11-2015, 02:34 PM | #6 | |
Useful Idiot
1330
Rep 1,777
Drives: My wife and kids insane.
Like boobs, fake or not, sometimes you just need something good to hold on (or listen) to Their authenticity isn't THAT important to me
11-11-2015, 02:51 PM | #8 | |
Rep 12,312
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
11-11-2015, 04:11 PM | #9 | |
Rep 3,945
Drives: 2015 M4 MG/SO
I would find it odd that BMW will disable ASD in newer firmware updates. If you want and miss ASD, you can try diagnosing it with Rheingold. |
11-11-2015, 04:17 PM | #10 | |
Rep 109
My plan is to code things to F86 and S65TU tonight and see if the sound is *any* different. If not, then my ASD module itself is definitely not functioning properly. Do you know where I can find a legitimate copy of Rheingold? TIA.
Past: '13 W204 C63 MCT, '12 MKII TT-RS 6MT, '11 E92 335is 6MT, '06 MKV GTI 6MT Last edited by Stryder; 11-11-2015 at 04:24 PM.. |
11-11-2015, 04:18 PM | #11 | |
Rep 109
The break-in service doesn't touch the software.
11-11-2015, 04:18 PM | #12 | |
Rep 109
11-11-2015, 04:59 PM | #13 |
Rep 3,945
if you'd like, PM or post your ASD cafd and i can compare it to mine CAFD_00000F9B_001_017_001.ncd
11-11-2015, 05:24 PM | #14 |
Rep 109
Sounds good to me! I'll do that tonight.
11-11-2015, 06:56 PM | #15 | ||
Rep 516
11-11-2015, 07:19 PM | #16 |
Rep 3,396
Unless it's manditory, and even then I'd put up a fight, I would never ask for a software update changing what came in from off the line out of Germany. Went through enough of it and learned a lot from my previous experience with my N54 and sw changes. Never again!
11-12-2015, 02:37 AM | #17 |
Rep 109
Another data point:
Quickly coded the car to F86/S63B44, *zero* sound difference. My ASD module is basically non-functional. Tired. Must sleep. Didn't have enough time to figure out how to save my cafd to ncd. Take care of that later.
11-12-2015, 08:01 AM | #18 | |
Rep 3,945
- click on "Read SVT" button. - Right click on each green CAFD and click on "Read Coding data". - files will be saved in your C:\Data\CAF dir Once you get the "other" software installed, do the following: - check the faults that you may have, given that you have changed some of the ASD params, you will have the following fault from ASD ECU (8053A5 ASD:Invalid coding data for equalising - ensure that your ASD is coded back to stock defaults (Esys) - clear ASD ECU faults - drive, restart car, ... then check if you have still have any faults |
11-12-2015, 01:31 PM | #19 |
Rep 109
Update:
By this morning I hadn't had my own software properly set up yet to do diagnosis, so I stuck to my dealer appointment and had them take another look. What they found was that the ASD module was not responding to the test plan, and their conclusion was that the ASD module must be bad. They've put in an order for replacement and also sent the test plan results to BMW eng. Without having ran the test plan myself, my intuition says that it's unlikely that the update somehow completely fried the module itself, and it's more likely that there's corrupt data and/or bad code that is crashing the unit hence rendering it unresponsive, and that this might be related to the update which fixes RTTI (fix one bug, introduce another type of deal), but I am really just spit-balling by this point. Going to try and run some diagnostics myself as next step.
11-12-2015, 02:54 PM | #20 |
Rep 3,945
hi, check the diff between your file and mine, not sure how critical "construction stage" is, but yours is set to werte "06", unknown ? for fun, try setting that to my value werte 03 ?
and you could alway VO code the ASD ECU to bring back to stock if there was some coding/firmware update corruption, i think but unsure ! |
11-12-2015, 02:58 PM | #21 | |
Rep 671
11-12-2015, 03:10 PM | #22 | |
Rep 3,945
