03-18-2022, 09:28 AM | #1 |
Rep 3,034
Drives: 2019 M2 Competition
Interim dyno results - Mosselman MSL65-80 turbos - Initial runs with pump gas and E85
Ok yall.. the INITIAL results are in for the Mosselman turbo installed, with Cary Jordan tuning.
These turbos are EXTREMELY strong, smooth and have run flawlessly thus far and clearly have a ton of headroom left at this stage. - PLEASE READ FIRST - 1. Massive tire slip on every run, so torque is actually underrated a bit. Nothing we could really do about it at the time. Warmer tires on later runs helped but were still an issue throughout. Combination worn rollers and need different tires to hook that kind of power. 2. This was a 92oct pump gas run first on a nearly empty tank, then 5gal of E85, bringing it up to E65 registered in the tank 3. My stock HPFP absolutely falls off a CLIFF after about 6400rpm running E85 (I was reading E65 on the BM3 sensor) with every run. Cary did an amazing job working with that, but its clear the HPFP needs help to get really serious on E85, so we dialed the tune back for now. There is clearly significant head room with proper fuel support. 4. These are interim results for E85. Pump gas is dialed in essentially perfectly, but E85 requires more changes to accommodate the fuel, which is likely in the future with HPFP and EU5 injectors. 5. I included the best stock turbos, custom tune run for reference, so you can see the improvements. Custom S2 Mosselman turbos with pump/flex fuel tune from Cary Jordan, on a Dynojet at CarbConn in Kirkland WA 92 octane RWP averaged STD corrected - 588.12 92 octane Torque average STD corrected - 484.09* (serious tire slip throughout) E85 RWP averaged STD corrected - 632.35 E85 Torque average STD corrected - 573.78 (still some tire slip) So for comparison: 3/11/2021 - full stock OEM tune RWP averaged SAE corrected - 403 Torque average SAE corrected - 466.85 3/17/22 - E85 custom tune with new turbos E85 RWP averaged STD corrected - 632.35 E85 Torque average STD corrected - 573.78 Juuuuust a little difference..
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread Last edited by BMW DIY Guy; 03-25-2022 at 03:26 PM.. |
03-18-2022, 01:59 PM | #2 |
Rep 552
Drives: 2018 M4 ZCP 6MT
Awesome results man, and yet another great informational video!
And speaking from experience, once the EU5's and HPFP's are in it'll be an absolute game changer
2018 F82 ZCP 6MT: FBO, Kratos KRAS55Bi, EU5 Injectors, Dorch HPFP Lift Kit, Stage 3 LPFP, Bend Calibration Zeitronix ECA-2, BM3 Flex-Fuel Tune by ABP
For Sale |
BMW DIY Guy3090.00 |
03-18-2022, 02:20 PM | #3 |
Rep 3,034
I appreciate that thank you! I am working on it.. while pump gas is perfect, and I likely will RARELY run E85, I would love to finish out the build with HPFP and injectors. (maybe LPFP as well)
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
03-18-2022, 04:44 PM | #4 |
Rep 548
Crazy thing is I was waiting on kies motorsports to show his dyno numbers from these turbos, I wanted to see how they compare to pure turbos
03-18-2022, 05:09 PM | #5 | |
Rep 3,034
It's clear though at least for me, these are very strong capable urbos.
M3SQRD2315.00 |
03-18-2022, 06:25 PM | #6 |
Rep 148
Looking great!!
So that is with downpipe, midpipe, and stock exhaust?
15 BMW F83 M4, MHD Stage 2, CBC, xHP Stage 2, ADD W1 Catchcan, AA Single Mid, Eibach Pro, 12.5mm spacers, BMC drop-in with charcoal removed, other misc/cosmetics (Alpha 1 speakers, all exterior LED light bulbs, ambient light upgrade-center console/doors, Hardwired Garmin Dashcam)
15 BMW X3 x35i |
03-18-2022, 06:57 PM | #7 |
Rep 3,034
All Active Autowerke now, DPs, EL midpipe and their new axleback exhaust
03-19-2022, 12:31 PM | #8 |
Rep 1,158
This is great. Now I'll actually have another vehicle to compare to since I was planning on dynoing there too.
03-19-2022, 12:34 PM | #9 | |
Rep 3,034
Looking forward to seeing your runs!
03-19-2022, 12:41 PM | #10 | ||
Rep 1,158
03-19-2022, 12:45 PM | #11 |
Rep 3,034
Dorch and EU5 are absolutely now on my radar to finalize the E85 tune
sly1types431.50 |
03-19-2022, 12:46 PM | #12 |
Rep 3,034
Unless you have already ordered. I STRONGLY recommend the Mosselman turbos. Plus I hear Pure is months and months backlogged where MSL is not.
05-29-2023, 01:10 PM | #13 |
Rep 326
Any updates? I just seen Kies Motorsport video and they made over +800whp and 700plus ft lbs of torque! Not bad for bolt on turbos. I know he's on built motor but still impressive for another bolt on option.
05-29-2023, 01:15 PM | #14 | |
Rep 3,034
Cary is a genius
CT92F80137.00 |
05-29-2023, 04:12 PM | #15 | |
Mod Junkie
52
Rep 59
Good numbers for both port and full E85, especially with how the TQ curve comes on with the Mosselman's. |
05-29-2023, 07:47 PM | #16 |
Rep 40
Wow, that's making some jam! What did you end up doing for a rear tire to get the torque slippage under control?
05-29-2023, 08:42 PM | #17 |
Rep 3,034
Still stock 19s with Supersports. Can spin really at will but enough grip to.get the job done when I want. I was starting to spin up tire and wheel change ideas, but the F87 sale and G87 inbound has changed that.
10-08-2023, 11:14 PM | #18 |
Rep 902
Is it necessary to upgrade your fuel system, or can I run them on stock fuel system on maybe E30? If so do you know how much power that would make? Thanks
10-08-2023, 11:16 PM | #19 |
Rep 3,034
You can definitely run them.on stock fueling but of course improved fuel helps at every point. Impossible to guess what your results might be, but if you check my F87 build page (in the sig), you can see the progression of power over time.
Jbonly211093.50 |
10-08-2023, 11:22 PM | #20 |
Rep 902
Thanks appreciate the quick response, will do.
https://youtube.com/user/Jbonly21
03-23-2024, 06:54 PM | #21 |
Rep 939
Is the Map1 670 with with Eu5 injectors and Dorch lift kit?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
03-24-2024, 01:09 PM | #22 |
Rep 3,034
That is correct, pump gas as well.
